for discussion
Bt Doctur
alpha Gen II housing that was taking on a lot of water. Suspected of using regular bottom paint instead of outdrive paint over the years. What do you think?
tank1949
Living in NW Florida and having a boat for 65 years, I learned to never keep an I/O stored wet in salt water. An inboard is a different story.
looks like it was chewed on by an angry beaver
Ayuh,...... I've got an Alpha 1 transom assembly that lived on a boat with twins, that was moored in I believe Conn., has that sorta problem,.....
Where some sand/ crud or whatever held water against the housing, it rotted through,....
kenny nunez
There is a marina somewhere in Nova Scotia that has under ground power cables. At a OMC seminar they showed us a picture of a drive completely eaten off at the water line.
