Baxterdmutt
Thread starter- Joined
- Aug 16, 2024
- 10
Hi guys!
I was given this motor and was told that it hadn’t been used in over a decade but did run back then. I’ve done a lot to it and it seems to run pretty well other than it’s a smoky pig. After replacing the water pump impeller I’m still not getting water from the peepee hole. It’s not plugged. You guys probably know this but there is a hole with a plug in it at the top left (looking from the back) rear of the block that you can check for water. I put a connector in the hole, attached a tube, and started the engine. Water will come out but only if it’s lower than the motor. There is no pressure. So I took the bottom gear box back off and ran water through that tube that I put in that test hole at the top of the motor, to see if water comes out of the water tube in the leg. It does but it also runs out somewhere at the base of the motor. I can’t clearly see from where. If you are standing behind the motor and look up the leg, the water comes out from the left and it sure doesn’t look like it’s coming from anywhere near the copper water supply tube.
Before I go through all sorts of trouble taking the motor off the leg, is there something in that area that is suspect, or is it likely a cracked block.
