OnThePontoon89
Thread starter- Joined
- Aug 8, 2024
- 14
Symptoms are as follows
Videos
- Boat-CarbGas - This video shows gas spitting out the carbs.
- Boat-CarbBag - This video shows me covering all carbs with a bag. Only covering the middle kills the engine.
- Boat-PullPlug - This video shows me pulling all plugs on the motor and observe no change. Pulling the middle kills the engine.
- Boat-2Plugs - This video shows the motor running with cylinder one and cylinder three's plug wires removed.
- Idles fine at 800 RPMs however when put in gear the engine bogs out. To get it to not bog under light load I have to set the idle very high. The motor will then idle at 700-800 RPM in the tank but scream on muffs. If I do not adjust the idle very high it will run fine on muffs. This condition only presents in the water or tank.
- At WOT the engine is non responsive. It will very slowly climb to about 18 MPH.
- Compression is fine. 110 - 120 PSI.
- All cylinders appear to "spit" fuel however cylinder one seems to do it the worst
- When covering cylinder one or three with a plastic bag there is little if any change. When covering cylinder two the engine immediately dies.
- When removing the spark plugs from cylinder one or three the motor runs the exact same. When removing from cylinder two the engine immediately dies.
- I put a spark plug tester inline with all three cylinders. I have spark. I shocked myself on cylinder three so I know for a fact I have spark.
- Pulled the plug on cylinder three and ran the motor. I really don't smell gas nor do I see gas\oil shooting out the hole. This is idle.
- The test tank is very oily after about ten minutes of runtime.
- Not sure if this is an issue but if you watch the last video at the 4 second mark you will notice water pouring out between the mid section and tail section. Otherwise it pisses fine.
- Some mechanic did supposedly rebuild the carbs. Before the carb rebuild I would completely die at WOT and could only idle. I did not run the boat for two years after the rebuild.
Videos
