Eastboundndown
Thread starter- Joined
- Apr 21, 2017
- 74
Hello everyone, I’m a new owner of a straight inboard boat equipped with a fresh water cooling system. Yesterday I had my starboard engine start overheating so I shut it down and limped in on port. I just located what I hope is the only problem with cooling system. One of the copper 90 degree hose fittings on fresh water side of heat exchanger is physically loose. No antifreeze left in system so I’m guessing it was all pissing out at that elbow. I have done a decent amount of soldering copper pipes before the industry changed to pex and crimp. I guess what I’m asking is can the fitting be removed and replaced in the same manner as residential plumbing or is that wishful thinking and I should try to find a radiator shop to do it. If those even exist anymore. I would really prefer to have it fixed by brazing/soldering then try using some type of epoxy. Any helpful input is appreciated. Thx
