2001 200hp Carburetor Torque Specs
Scode68
Hi,
I'm looking for some torque specs for the side plates and bowls on a 2001 Johnson 200hp J200VXSIF. would like to know what a Evinrude manual says cause I think the SELOC numbers might be incorrect. Mechanic said they should only be like 15 inch lbs.
Why yes.----Actually I think it is 10 inch LBS for carburetor bowls.
Scode68
This is from the SELOC manual.
You will not go wrong by following your manual.----Good luck with the project.
Scode68
Tightening the side plates and bowls to the SELOC specs ruined the gaskets and deformed the bowls to the point the floats were hanging up.
Faztbullet
From the Factory Manual...
calibration pocket gasket...10-15 in lbs
side cover...24-30 in lbs
high speed jet....30-35 in lbs
float chamber...18-24 in lbs
Send me PM and will send you the pic as site will not allow post for somereason
Scode68
That’s what the SELOC had, but they cut into the gaskets to the point where I had huge air leaks. This was also with using the new BRP kits. Dealer/mechanic said that I shouldn’t go over 15 inch lbs.
