scottie9656
Thread starter- Joined
- Aug 1, 2024
- 9
I just bought a 1981 9.8Hp mercury V.I.N. # 5881663. First thing I did was change the impleller, thermosat and rebuilt the carburetor. First round in the test tank it started up fine but only a few spurts of water and exhaust through the tell tale. I shut it down right away. After doing some research on here I removed the powerhead and found the plastic washer between the motor and water tube was melted. Replaced that. Now if have a pretty good flow of water at idle and a strong flow when in gear. The tell tale water is extremly hot. Could I have a blown exhaust baffle gasket causing it? Motor has only been ran in fresh water.
