hercules100
Thread starter- Joined
- Mar 20, 2021
- 7
Hello: This is my first post to site. I also have a SeaRay 1984 3.0 last week I was going across the lake 2500 rpm, trimed out and all of a sudden the engine just bogged down like it was out of gas, it idels ok, but know I have a "nocking sound" and I can feel it on the gunnels/floor. I idedled back to the dock and have been looking for problems everysince. I have changed the fuel filter, spark plugs, compression tested out at 140 psi even on all cylinders I also let the gauge set for 10 minutes on each hole, no bleeding back. oil is clean and full, checked timing, rotor cap and wires. I pulled the outdrive to check out the U-Joints and replaced the lower cable and water pump, they were ok, but replaced also the bellows, water pickup hose exhaust bellows, shift shaft bushings. seal kit etc. I'm scratching my head, but this is not helping.
