DeepCMark58A
- Joined
- Aug 17, 2015
- 3,202
I have a single pinstripe I want removed, do the erasure wheels work as well as advertised?
I always used a heat gun and a razor blade. once you start peeling it, peel it back on itself with just a tad bit of heat from the heat gun.
I've used one one time, and it did really well. I had a large area to do, so it was nice to have. BUT, you still have to go back and clean up a little here and there with ... yup ... heat gun and a razor bladeI have a single pinstripe I want removed, do the erasure wheels work as well as advertised?
I would think the numbers would just freeze off in Minnesota... Will use the erasure when I reregister it in MN and remove the old numbers and license stickers.
They don't Northern Wi here, -40* at times.I would think the numbers would just freeze off in Minnesota![]()
which is why this cheesehead now lives in Florida....They don't Northern Wi here, -40* at times.
This boat will not see temps below 40, only time it is wet is when it is being used. I bought it as a stored indoors boat when not in use will continue that.I would think the numbers would just freeze off in Minnesota![]()
The cold winters used to keep the riff raff out, that has changed.which is why this cheesehead now lives in Florida....
