1973 Gibson help
There is an impeller inside
Look for a thru hull shutoff valve and close it. Then remove the pump and disassemble
Does look like the G7B and if correct look for rebuild kit
If pump needs complete rebuild with bearings I found this one
Rebuild
Bdunbar44
Impeller on the left came out of the generator one on the right came out of the boat. Definitely needed to be done. Thanks guys!!! I’m also trying to find a thermostat for the CN6-33 diesel engine. If anyone has a part number please share.
Good deal
I would suggest get a manual like this one on EBAY
It list part numbers which will always help
Might also take the thermostat to NAPA or other parts house with a old white haired guy behind the counter
now you get to go spelunking for the missing impeller bits that are clogging up the rest of the raw water cooling system down stream
