BigLantastic
Thread starter- Joined
- Feb 26, 2021
- 14
Picked up an old 55EL78S. It would start an run for about 5 seconds. Then die. So I took off the carbs, cleaned them and put them back on. Then it started and ran rough, and poured gas out of the bottom carb. I decided the float was hung up and that was probably flooding out the bottom cylinder....well...I freed up the float and the fuel stopped spilling out. I fired it up and it would still only run on the top cylinder. Cleaned the spark plugs and checked the spark with a spark tester. They are both sparking while it's running. But I can take the bottom wire off while it's running and nothing changes. It was running on both before, but only for a few seconds. Now it keeps running, but only on one cylinder. What did I do wrong?
