Hi,
I recently bought 1985 Evinrude 15 hp and im having trouble getting it to start. It has spark and compression on both plugs and cylinders. The fuel pump works when being pulled started and there is fuel in the carb bowl and the float and needle are good. When trying to be started the spark plugs stay dry which makes me assume fuel isn't getting out of the carb but I put my hand on the air filter port and felt it suck in and saw fuel come out. I have cleaned the carb multiple times and reassembled it. I hear it pop when I spray started fluid into it but without it there is nothing. I'm assuming gas is not getting to the spark plugs which makes me think it is a carb problem but everything in the carb looks good and the gaskets are good. Any help would be appreciated, thank you.
