Rudejonnie
Thread starter- Joined
- Sep 15, 2024
- 9
Hi all,
I recently acquired a 2000 Johnson 15hp (J15RSSM). It starts up and runs at higher rpm’s but will die at idle. Started with the typical full carb rebuild with an OMC kit (even swapped in a known working carb from a different motor), checking compression (100psi on each cylinder), checking spark, link and sync, fuel pump is good, ensuring bulb pumps till firm, good fuel/tank from working motor, etc with prior suggestions on different posts here and other forums with no change in the no idle issue.
I did notice the installed fuel pump is part number 438556. The correct fuel pump should be 438562 (already on order).
My question is would the incorrect fuel pump cause the no idle issue? Perhaps the 15hp not providing a strong enough pulse to supply the correct amount of fuel flow for idling?
Thanks in advance for any insight.
