Swedefj40
Thread starter- Joined
- Jun 9, 2018
- 225
So I replace the impellor in my 1998 15HP 4-Stroke Merc (OG674558) this spring and, in the process of reinstalling the lower unit up into the outboard, the small round coil (spring) that is seated around the lower lip of the crankcase seal, came out with the shaft. Would this be enough to allow water into the crankcase oil? I don't get a lot of water in it and the engine oil level doesn't change at all either. This is usually the case after running it for 15-20 hours at trolling speeds. I don't get any oil sheen on the water around the outboard either. You'd think that, if anything, I'd see some oil around in the water as that seal is high out of the water and that the engine oil would likely seep out down the shaft as opposed to water pushing up through the seal into the crank case? Is there any other common place that I should look into on this particular outboard for water ingress? Thanks!
