erickdiaz2002
Thread starter- Joined
- Oct 1, 2024
- 3
I recently bought a 2001 century with 2 yamaha 200 hpdi one is good but I am having some trouble with the other one. When I connect the engine to the yds software the first thing I did was check the code it had 2 which were 1.Pulser coil and 2. Shift position switch. After taking a look at the shift position switch we realize that the metal thing had gone off of its position we never got the code again.We also replace the Pulser coil but we are still getting the pulser coil code after the new one. On idle the engine is running very poor it doesn't turn off but on the yds software I can see the rpms are going up and down and not staying constant, It goes up to 700 and decreases to 450 rpms. The yds software shows the timing going crazy this is what it shows (5 btdc, 6 btdc, 7 btdc) going up and down like the rpms. I got the rpms up to 2600 and it stayed at 7 bidc but when I checked the firing of the cylinders it never stays with all 6 some cylinder turn off and the turns back on fluctuating. I also replaced every fuel filter and cleaned the vst. I also did a compression test and got 90 on all the cylinders . Any idea what can it be. The only pictures I have are when it was at 2600 rpms. If anyone can help I will really appreciate it.
