Hi,
Yesterday I picked up the boat and first step was to remove the Mercruiser sterndrive. Engine is a Mercruiser 165HP.
Gimbal bearing still moving smooth. Gimbal bellow in good condition. U-joint is moving smoothly and no play issues.
BUT: quite some oil in the bellow.
I suppose that there is a very low propability that this comes from the engine. So most likely the oil seal from the upper part of the drive is leaking.
Next steps I will take:
1. Remove the top-lid of the upper part with the 4 bolts and visualy inspect the inside bearing/gear (need to order a socket...).
2. Drain the oil (I only see a oil screw in the bottom part of the drive and a vent in the upper part)
Question as next step:
3. Do a pressure test (10psi I read somewhere) OR start disassembly of the upper part?
Or any other suggestions for the next step?
Should I have created a seperate post for this question? (first steps in this forum)
Does anyone know what type of sterndrive this is? R or MR? (see picture).
It has this eye on the top to lift the drive.
(I know it needs cleaning up)
