Redline 302 removal
LCS010103
I have a '96 19' Duckworth with a Redline 302 and an American Turbine Jet drive. I need to pull the motor to rebuild it. Any tricks or advice to disconnect the outdrive from the motor? TIA
Ayuh,..... Welcome Aboard,...... Unbolt the driveshaft,....
LCS010103
Thank you. I left the driveshaft connected to the flywheel and let the slip yoke come apart. I hope that was OK.
Any Ford Redline engine manuals out there?
Ayuh,...... Could be, but I've never heard of Redline,.....
Scott06
you may want to mark the slip yoke so it goes back together in same place on the chance that it was balanced together like a driveshaft
Too late for that. Motor is out and at the machine shop.
Ayuh,..... There may be a blind spline for alignment,....
If not, slip it back together with the caps in-line, or at worse, 90* from in-line,....
If you don't, it'll vibrate, Badly,....
LCS010103
Thank you for the advice! Much appreciated.
