Alert
Fartdust
1991 Suzuki 55 DT alert sounds when turn key on then quits when motor runs.
airshot
I have not heard alerts sound before starting engine.
Most all of my out boards from late 80's up to present have an alarm test when the key is first turned. It is used to test the overheat sensor on my current motor, to let you know it is working. Usually found on motors with electric start. If you have a manual start, then it might not sound an alarm test.
