VP 5.7 GXI Tachometer Sending unit
Berkley1
Trying to locate where the tach sending unit is located on the engine?
the tach is connected to the coil. the ignition firing the coil is what sends the signal to the tach. hint: its the grey wire
most tachs run off the coil
unless they are networked gauges, then they run off the CAN backbone
