Winterize Tohatsu 50hp 4-stroke on boatport . . .
BuckyBuoy
Hey boaters,
My 1995 Lund Explorer Dlx pretty much stays on an EZ Dock boatport year round. The Tohatsu 50hp 4-stroke motor is locked down at about a 45 degree angle to keep the bottom unit out of the brackish water. But that prevents me from doing a simple winterization by dropping the motor to vertical and letting it drain, as if it was on a trailer. In the past, I’ve let pink antifreeze flow through muffs, while the engine is running, until it comes out of the bottom unit holes. And pouring some antifreeze into the upward facing prop bearing.
The motor has a fresh-water flush port to rinse out saltwater. I’m considering using a low PSI of compressed air to blow any remaing water out of the engine. Tohatsu tech says it’ll suffice as long as I pour antifreeze into the prop bearing.
We’ve got some cold overnights coming up here in Coastal Carolina with temps as low as 26F, and I wanted to get your thoughts. If would make my life a whole lot easier if I don’t have to hang over the stern while maneuvering those muffs in place in order to run antifreeze through the motor (I’m a ’seasoned citizen’).
Thanks!
tilted up wont clear rain water either, which can freeze in the exhaust cavity . I would find a way to raise the boat so the motor can be down all the way
BuckyBuoy
Thanks, Scott, for your reply.
The exhaust is through the prop. Apparently, that’s why the Tohatsu Tech told me to make sure I pour the antifreeze directly into the opening, to protect the bearing.
I wish I had opted for a traditional lift, but my wife wanted a lower profile situation so as to not impact the view from the creekside porch. There is no way to elevate it on the boatport.
Thanks, again.
MattFL
I'm a FL native and we don't winterize here (i.e. I have no winter experience) so with that in mind: since it has a flush port, can you use a small pump to pump antifreeze into the flush port while it's tilted 45 degrees? If you turn the motor vertical after fresh water flushing, the top part will drain, only the bottom will be contaminated by the brackish water. So when you tilt 45 degrees after flushing, the top will be empty of water. BUT if you pump antifreeze into the flush port while it's tilted, I would expect that to get antifreeze everywhere the water normally runs, including the lower unit and exhaust, and anything remaining in the top half would be antifreeze.
airshot
Just how much of a gambler are you ??
if the lift doesnt go high enough to get the leg out of the water when the motor is straight down, either remove the boat from the lift, or the motor from the boat.
or the lower can bust like this.
https://img1.wsimg.com/isteam/ip/528db6ac-3fa1-4b9e-bff2-378d16e63c6f/marine%20surveyor%202.jpg
Drill 2 wee drain holes so rainwater cannot collect in the lower unit exhaust cavity.
MattFL
You would have to be very careful about location, the front part is gearbox full of gears and oil.
Ouch! Coming from the south where it doesn't freeze; my initial thought was the open end would be plenty of room for the water to expand as it freezes.. but I guess it expands in all directions even when one direction has no resistance!?
It still freezes here in Florida. have had frost in Myakka the last few mornings . There will be a bunch of freeze busted lower units and motors this year.
If water freezes in the bird baths, it freezes in the outdrive cavity
MattFL
I'm south of you (Palm Beach Gardens) and can't remember the last time I saw frost here. We had some light frost on the grass back in the late 80's/early 90's, but I don't remember any since then. I've never seen anything freeze damaged here. It's interesting that you see it where you are, I didn't think that was far enough north.
last winter we had 2 nights in the 20's. expecting about a dozen this year.
airshot
With all these so called global warming issues, who knows what temps the future will bring, so why gamble ??
Mc Tool
Ensign
I dont really have a freezing issue here in south NZ (I did loose my waterblaster pump a year or 2 ago ) so not a lot of experience but I cant see an issue with drilling a drain hole as racerone says , granted you would have to be careful as to just where the hole is put (as MattFL says ) and it would pay to check it for blockage periodically .
If one was to fill the exhaust cavity with antifreeze could you not then cover the opening to keep rain out ( maybe remove prop ) to stop dilution ?
