80stumpknocker75johnson25
Thread starter- Joined
- Dec 30, 2024
- 6
Got this older motor from my uncle been bringing it back to life so far I've done a carb rebuild,fuel pump and lines(except line from fuel tank),points kit,impeller and plugs (I have not replaced coil packs).
I have great spark on both plugs and it runs fine in the bucket at the house in all gears and ran good for 2hours after everything was done planed out ran 22mph no problem.when I get out in the lake now forward gear won't go above a high idle reverse throttles up fine it idles great shifts good I replaced the drive pin after the last ride it was a little old but not to bad but now I got no clue as to why it won't run in drive like it used to.
