FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Depends on the motor it is part of. List all the motor data on the motor name tag plate.
A photograph of the bent cable AND the motor will get a really good answer.
All motor cables are not the same.
Backing up the boat in my garage, motor turned all the way to the right, hit wall with black pads on it and bent cable. I tried to bend back cable straight but to no avail? The black on the wall is a rubber padding. Far right is garage with jog in walls!
Gee, I do not see the bend. I did see some pictures of your shop, plus some others I cannot id. However, if there is a bend in the cable and the cable end will not pass thru the tilt tube, you need to cut it off and pull out the stub.
yes I did get part of it straight but it gets stuck when trying to turn to the right and stops? Thank you for your help very appreciated. Cut into the rubber on the wall and crushed the sheetrock.
