Bottom paint
Kevinnowels
I have an old 1669 Glasspar I am restoring. I’m almost to the point of paint and pricing everything out and getting materials list. The boat will only be used about once every 2 weeks in summer then sit on the trailer for most the other time , it won’t be kept in the water . What kind of bottom paint do I need to use ? There are so many kinds and price ranges . I’ve read that I need ablative even if it’s trailered, and I’ve read that you don’t need it if it is trailered . Someone have any recommendations?
Depends on what water it will be in.
If it's fresh water, wax is all you need
Kevinnowels
It will be in fresh water only.
Do you mean gel coat with wax when you say wax ?
Looking for a cheaper option even if I have to repaint the bottom in a year or so
Trailered boats do not need any paint on their bottoms. The gel coat from the factory is just fine. If you do not like the look of the gel coat, any marine polyurethane will make it nice and shiny, with the correct prep.
If you use a one-part polyurethane, the boat cannot be kept in the water, but daily use and trailering overnight is just fine.
Kevinnowels
Thank you that helps . One part polyurethane is just topside paint correct? That’s what comes up when I look it up.
Yes, one part polyurethane paint is considered to be topside, but there are other topside paints which include enamel and other formulations. I believe polyurethane paint to be superior in shine and hardness to them. Their price is also higher.
flashback
I think what he meant was a can of paste wax and elbow grease.
Kevinnowels
Yea the elbow grease is already in place and paste wax won’t do it . There were a lot of cosmetic imperfections and I’ve already faired everything and sanded smooth . The fairing compound being a different color and the paint was yellowed and faded so need something to make it like new again
Kevinnowels
Thanks again
1-part top side paint is only good for a few days under water.
Gel is what I would do on the bottom. And then boat wax to wax the hull to keep growth at bay.
However if you are going to use a 1-part paint, I would recommend bottom paint (easy to apply, not aesthetically pleasing)
Antifouling paint on a trailered boat is not ideal, IMO. It will rob some speed, not look good and wrongly announce that the boat was kept in the water, which is bad for resale.
Kevinnowels
Thank you for your help . I’m thinking of staying away from bottom paint since it won’t be kept in the water. Don’t want to waste money on a paint that won’t be used for what it is for
MikeSchinlaub
Something to keep in mind. Even though it's on a trailer, the bunks keep their contact areas from drying well. This will cause blistering in those areas. The anti-fouling, I have been told, isn't porus like gel. So it will help prevent this.
Gee, Mike, I have never seen blistering on a trailered boat with bunks. Of course, a roller trailer eliminates that worry.
MikeSchinlaub
I have when we lift them to work on the bottom. Usually lots of tiny ones. It is less vommon, but can happen.
MikeSchinlaub
Although to be honest, I don't know how they are normally kept or how much time they spend in the water.
My speedboat sits on a lift with bunks all season. It has one-part polyurethane topside paint on the entire boat, however, I never had even one blister. I think it is a non-issue.
You don't leave it in the water cor more than a day
JKLknik
VC-17 is widely used on Lake Ontario. It won't, however last for 5 years. It takes about 2 to 3 cans to do the bottom on my Sabre 30.
