Hi All, I did a compression test and got readings 110, 125, 120, 115, 120, 125 which is average for a 2 stroke. The engine now has problems starting, and when and if it starts it also running on 4 cylinders intermitted. I have spark on all 6 cylinders, and sometimes at half throttle I hear/feel it running on all 6 cylinders and goes fast, then it will bog down and run slow on 4 cylinders. I think it maybe a fuel problem. The fuel bulb use pump to a hard status. But when I recently I took off the 3 * carburettors and cleaned whole unit including all the jets. I did not replace the needle and float within the carburettors and the looked and operated fine, I also cleaned the internals of the fuel pump as well, cleaned fuel filter which sits next to the fuel pump (within the engine), but it did not resolve the issue. The fuel tank (140 Litres/35 gallons) is under the floor and used about a 2.5-3 metres (9 feet) fuel hose. It is pumping fuel to the fuel pump and to the first carburettor , the second and third carburettor are daisy chained from the first and fuel pump.
I think the fuel hose may be too long, or I may need to replace the coils or power-pack? It still have the constant beep on start-up, but it is not overheating or low on oil.. Any comments will be appreciated.
