todd3ponds
Thread starter- Joined
- Nov 7, 2024
- 2
Hi - I've got a 1978 Mercruiser MC1 (I think) sterndrive Model 260 Serial # 5059876 that I'm rebuilding. New drive shaft, drive gear, and bearings. This problem I'm facing is that the new design has a thicker/taller driven gear and shorter lower bearing underneath it than the original (so the height is exactly the same), so I need to remove the bearing cup from the housing, because the old and new size and slopes are vastly different. (and yes, I've got a new drive gear and bearings, as well, already assembled and preload'ed - and the shimming tools)
Any advice on this? I'm about to attempt to use my generic two-arm puller & slide hammer, but I wanted to know if there's an easier/more elegant/less-potentially-damaging way to do this. Anyone done this before? A tool that works well that isn't expensive?
The other concern is: these cups fit in there really tight. When shimming, is the process: press the cups in, install and close up, check the clearance, take it apart, drive the cups out, fix the shims, rinse and repeat?
Thanks!
Thanks!
