Prepping for gel coat
ethanwerl
On the last stretch of the project and was curious of how much I would need to sand to start applying gel coat. Now I know half of the project is the sanding which I’ve felt the pains. Could I apply to the sanded portion or do I NEED to absolutely sand bare and start there?
Sand everything with 40 grit, then follow back over with 80 grit
Are you spraying? If so, I recommend the Duratec 904 additive
MRS
No need to sand the old gel off. You just need a good sanded surface, clean it with wax and grease remover, and you should be good.
Yes wax and grease remover the main thing let us know how it turns out.
