swap a microwave for a larger refrigerator
oldbouy
I have a 1991 Bayliner 2655 , it has a small drawer type refrigerator and a small microwave under it , any pros or cons for replacing both units for a larger refrigerator ?
I do not see a need for a microwave on this boat . or should I keep them both the way they are ?
Don't know the exact boat, but don't see an issue replacing with a large fridge
Grub54891
Pictures of the area helps. We had a customer that wanted to do a similar thing. It would have required removing the sink, cabinets and attempting to re-locate those items. Space was limited and he had bought the fridge and microwave already. No way they were going to fit in in there!
crazy charlie
Small drawer type of refrigerator??? What is that?? I would always welcome a larger fridge but a microwave is a very handy thing to have and I would not sacrifice it for a larger fridge on my boat. You can always use a cooler or plug in cooler if you need extra room but everyone is different depending on how you use your boat.Charlie
mike_i
How would the power requirements be affected with any change?
bigblocksarefun
You've never seen one of these?
ESGWheel
Ensign
This is the right question to ask and need to fully explore and have locked down prior to making any purchase of a new unit. While more then likely the power you have for either the existing m/w or refer will be sufficient for the larger refer, but you have to do your homework on this else risk a fire. I am assuming each is on its own circuit but if only one ckt powering both, the below logic still applies.
But its easy enough: Start by determining your breaker or fuse size for each of your existing units (Amps and Voltage). Compare those numbers with the specs of the unit you are considering to be sure you are well within the amps (its assumed will be the same voltage). If yes, then you are good to use that existing circuit. I define ‘well within’ as 80%. Example is the existing circuit is 15 Amps at 110VAC then 80% of 15A = 12 Amps is the max I would put on that circuit (12.5A would be ok too). This is just good practice, adds a safety margin, and accounts for startup surges for things like motors.
If you are searching for a new unit and the data lists Watts (power) then simply take your 15A x 110V = 1,650 Watts (Power = Volts x Amps). 80% of 1650W = 1,320W for that margin.
If the new unit you are considering is at, or exceeds, your current arrangement, then it is a whole different story and one that needs much more evaluation and planning. But it can be done. DO NOT attempt to add say two 15A circuits to get 30A! it does not work that way…
If want to continue the electrical discussion it may be best to move over to the Electrical Forum. Also, if you want to PM me, I will help as I can.
Good luck!
cyclops222
Wire size determines maximum continuous amperage a appliance can pull in normal construction locations. A circuit breaker CAN BE smaller, than the maximum allowed, by the National Electrical Code.
ESGWheel
Ensign
While true, its clear the OP is not familiar with the electrical side and do not want to give the impression that OP can increase his breaker size without a holistic evaluation and investigation of his installed wiring.....
cyclops222
O K
Read the Dometic 30 specs at Dometic website. No USCG or UL safety ratings. No airspace And cfm requirements.
I bet they sell a lot of replacements.
They recommend direct connection to battery posts. No fuse or C B protection Not specified.
Single battery boat. Hope not.
