I have twins on my boat initially I rebuild one motor and then noticed the second was full of water and rusted bearings so I replaced the front bearing and gear and the top bearing. I put it back and when I put it in gear at idle it would kill the engine. I took it apart and compared to the second drive when off the outboard and it did not spin freely as easy so I took off the thicker shims at the clutch and it did spin the same and play was similar at the prop. The issue with the turning off at idle persisted.
I rebuilt the second motor because it's really easy to do and that motor is perfect drives as it should.
When I use the boat I usually start it with the port good motor and only turn on the one that dies when at speed. They work great together.
The motor that dies at idle is set up with a little higher idle adjustment. It sometimes does not die especially when hot.
I did notice that that motor runs hotter than the other oneBoth motors were rebuilt the same way with all the wires redone and electronics new. Stator and triggers too.
Question:
Is the issue related to the lower drive not being shimmed by the book?
Is there an easy way to shim this drive?
I do have the manual and there are tools needed.The boat is a 24 footer Trophy 2302. It is a great boat for my needs. I have improved everything on it from the dash set up to gauge.
Buying newer engines and or boat not an option right now. Thanks in advance guys.
Question:
