I just completed a single piece batwing to two piece wet joint conversion on my 1998 4.3 i/o raw water cooled bayliner. I used all mercruiser parts including the graphite style riser gaskets. Prior to this, I also installed a new impeller, which I've done numerous times. Buttoned up the install today and fired the boat up on muffs in the yard. I ran it at about 2k rpm for maybe 15 minutes. The starboard side riser was 60 degrees hotter than port(150 vs 90). what's interesting is that the boat is slighly canted to the starboard side, but there is much more water shooting out of the port side, which is the cooler side. The boat seemed to run well, but I shut it off due to the riser temperature. the temp gauge on the boat stayed right where it normally does, 170 or so.
when shutting it off, it dieseled, which it's never done before. i saw some steam coming out of the starboard side exhaust. These are all new parts and i can't imagine what i did wrong. do i need to take it to the lake to really see how it does? i REALLY took my time on this job and was very thorough.
there was definitely water coming out of the starboard side, but not much compared to port.
what should i troubleshoot? thanks! this was a HUGE time and money investment.
