Oil Pressure Alarm
Joey9851
The shop is working on getting my new to me motor installed (2019 Mercruiser 4.3) and is having an oil pressure alarm issue. The original motor was a TKS and it’s being replaced with an engine without TKS (bought the engine with 5 verified hours for $1600 instead of $11,000 from mainland). The tech is going to diagnose next week but curious as to what direction you all can point me in so I’m not getting screwed on labor costs (already way over my budget). I have an oil sending unit in a box at my house, and the tech had to splice the engine to hull connector to get the motor installed correctly. Anything else to look for? I had them change the oil and all filters as part of the job too
Fun Times
Are both engines complete MerCruiser engines including all sensors and accessories/hardware/wiring,etc. or are certain parts being switched over to make the other work, etc.?
Is the other (new) engine carburetor or MPI?
Do you happen to have the MerCruiser serial numbers to either the new or both if parts are being swapped around.
Did the oil alarm come on before or after the new oil filter was installed?
Any other details to share on this procedure?
04fxdwgi25
I would install a cheapie ol mechanical oil pressure gauge in a "T" where the oil alarm sender sits, pull the spark plugs and spin it over with the starter.
That'll tell you if you have oil pressure / wiring problem or not and if it's just a bad sender or a bigger problem.
First, use the mechanical gauge to verify oil pressure
Second, the alarm is tied to oil pressure, gear lube reservoir, temp switch and a few other things. Trained marine mechanics will know this and be able to troubleshoot
Third....why not swap the motor yourself?
Grub54891
All the comments before are good. I've had customers who had alarms, a lot of times it's the drive reservoir float that is stuck from gunk. My usual service is removing the reservoir and flushing it out.
Joey9851
Both were complete Mercruiser engines, only thing missing was the connector from engine to hull. Both carbureted. Original serial is 1A066831 and new is 1G415169. Nothing from the original engine was saved
Joey9851
They tested the oil pressure with it running and it’s within spec, it’s just the alarm. Since my insurance company requires no alarm mechanisms activated, they have to get the alarm to stop.
Joey9851
First: they said the oil pressure was within spec on the boat gauge and manual gauge and engine runs great.
Second: they might not have filled up the fluids other than the oil when they tested it as they were confirming the harness work so I’ll bring that up to them. They don’t have techs that specialize in marine specific engines. They have an engine guy, an alignment guy, a drive guy and an electrical guy.
Third: My insurance company required that it be done by a shop. I filed a claim because the shop believed that the exhaust manifold failure that resulted in water intrusion would be covered. I don’t have the space or tools to do it myself. Mainly the ability to lift the motor and do the alignment.
Hopefully they get it finished up tomorrow so I can enjoy it before I have to sell as I’m getting ready to move back to the mainland from Hawaii
Joey9851
Is this the reservoir mounted on the front of the engine, in front of the exhaust manifold?
Fun Times
Thanks for sharing your serial numbers as it helps narrow down possibilities between the 2 engine models < and settle some of my Spidey senses as they were tingling on this one because your 1A066831 comes up as being a MERCRUISER 5.0L MPI ALPHA 1.7R DRAIN 5.0L ALPHA MPI
While your 1G415169 comes us an MISCELLANEOUS REMAN 4.3 ALPHA 4V REMAN - which your correct this engine will be a 4BBL carbureted version…
Here’s you part catalog for this model if ever needed, https://www.mercruiserparts.com/4-3l-gen--4bbl-reman-1g400000-thru-1g416776
That mentioned, sort of interesting that the engine size went down though the HP may stay close to each other but might effect either gear ratio and/or propeller sizing overall… have those concerns been addressed?
Joey9851
The original serial is wrong. It’s 1A633081. They’re both 4.3, I just got the numbers mixed up.
Fun Times
^ Gotcha, and that's good, as these models are usually a bit easier to trace down alarm issues vs the MPI... 1A633081 = MERCRUISER 4.3 TKS A 4.3L ALPHA
Hope filling up the gear lube reservoir will solve the issue for you all, let us know either way. :)
04fxdwgi25
Sometimes the float in the gear oil bottle gets goobered up and gives constant alarm, even when full.
3 possibilities:
Lube oil alarm
Oil pressure alarm
High engine temp.
All 3 are the same alarm with 3 sensors in parallel. Disconnect one at a time to see if goes away.
Joey9851
They said the oil pressure sensor is bad. I have another one sitting on my dresser at home but I’m trying to confirm which one they are talking about. The one that connects to the blue and brown wire just below the exhaust manifold on the port side that’s skinny or the short “fat” one that screws in and only connects to the blue wire via the long screw on the end of it. Either way, it should be completely up and running next week
Fun Times
If the engine oil warning horn is the only thing happening/sounding off then it’s going to be item number 8 that operates the oil pressure switch which is most times generally located up higher toward the rear near the distributor assembly, Portside.
Item number 2 handles the safety fuel pump switch while item 4 shows the oil pressure at the gauge.
Joey9851
Item 8 is what I have at home. They replaced Item 4, but my oil pressure gauge stays at 80 psi and they recommended I replace the gauge. The alarm only activates until the boat starts.
Overall, I am happy with the work they did and there are some minor things I can handle. My biggest issue is my throttle handle is really loose and my WOT RPM is well over 6000 now so I need to get that sorted. I guess that is what happens when you increase HP by 35 and switching from TKS to MPI.
