Fuel pump
Rinker85
I’m trying to replace a fuel pump on a 1988 60 hp 2 cycle 3 cylinder Mercury outboard.
The old pump number is 98766. I ordered a new one but it doesn’t fit. It has a knob on the back side that won’t let it seat properly. I’ve attached pictures of the old and new pump.
roscoe
Well, you have 3 options.
Take parts from the 2 pumps and make a good one.
Return that counterfeit pump and buy a real Mercury pump. Should be part number
14360A73 $125​
Or return the new one, and just rebuild the old one.
What is wrong with the original pump?
Rinker85
14360A73 $125​
I can only start the motor with a shot of starting fluid. After that, I can start it all day long no problem. So I thought I’d start with the easy stuff the fuel pump and fuel filter.
Rinker85
Also, when I took the fuel pump apart, there was specs of varnish inside the pump if that’s what you call it. The diaphragm was not punctured or anything like that so I put everything back together with the old fuel pump and still have the same issue.
rolmops
It looks like you took a perfectly fine fuel pump apart. I do believe that you problem is in your carburetor. Or with the position of the fuel enrichener on your remote. Starter fluid is very unhealthy for two stroke engines, unless you mix a bit of oil in with it
roscoe
You shouldn't need a great fuel pump to start the engine.
Pumping the primer bulb should fill the carb bowls with sufficient fuel.
An advanced throttle and a properly working enricher/choke should get it started
Agreed----This may not be a fuel pump problem----Simple test.----Have your able assistant operate the manual fuel pump while doing a cold start.
Rinker85
So is this knob in front of the remote the fuel enrichener? If so how do I work it? This is my late dad’s boat. I’m trying to sell it for my mom. I’ve had I/O s for over 30 years and I know nothing about outboards.
Thank you
The enricher engages / works when you push in and hold in the key while cranking the motor to start it.
Rinker85
Okay. I don't remember having to push in the key. It just turns. This remote is a 1988. Do know what the knob on the front of the remote is?
Possibly a throttle stop.-----Or friction control for the handle movement.----Try and push the key in and see what happens.
