1979 80HP Mercury kill Switch
Kissdude
Hi,
I was wondering if someone could please tell me, How does the kill switch work on my 80 hp mercury out board. What wires do I use to go on kill switch at motor? Right now I have to choke it to turn engine off and, will the 80 hp pee while in neutral cause im not getting any water coming out..
Thanks in advance
It should pee about 3 seconds after the motor starts.----And those motors need a new water pump impeller about every 3 or 4 years.
Kissdude
So then even in neutral is should pee hey and the impeller should be replaced. Might have finished it when I was turning the flywheel by hand.
???----The water pump is driven by the driveshaft.-----The motor should pee about 3 seconds after it starts !
Kissdude
Thanks, guess I was just making sure that it should pee when the motor is running. I know the importance of it.
OK, if the motor is a 1979, it will have 4 coils and 1 switchbox. The ign kill switch will ground the orange (or salmon)-colored wire, to kill the spark.
The orange (or salmon) colored wire will be avail on the switchbox at the engine, and avail inside the control.
Kissdude
Thanks, that info really helped. Now, any information on my hydraulic lift would really help. I have the lift with 4 hoses and am wondering what the coloured wires are for. I know green is up, blue is down when both touches to red but what’s the purple wire for?
Originally your PTT unit had a trim limit switch. It was on the starboard PTT bracket, and it plugged into the main harness under the splashwell. I think the wires were purple. The trim limit switches broke all the time, and the workaround was to unplug the limit switch and jumper the two purple wires in the harness together.
Kissdude
Could you tell me the difference between trailer position and up position. Does trailer mean it goes higher for trailering and what two wires operate that?
The trim limit switch was set to keep the motor from "trimming" out of the transom bracket. On the original control, push and hold the center button for trim.
If you wanted to trailer the boat, you push the top and middle button together to bypass the trim limit switch and allow the motor to "Tilt" all the way up.
On your PTT unit, the only difference between trim and tilt was the amount. The mechanicals were the same.
Kissdude
Very helpful..thanks.
Any way you could tell me what I might have done wrong replacing my impeller? Somehow I bent the bottom carb butterfly spring and now they don’t move together. I thought the leg was going back into place correctly.
The upper shift rod can rise up if not mated to the lower shift carb and impact the carb.
There is a molded plastic fitting that holds the upper shift rod in place, in the midsection. They often fall into the gearcase where they do not function, or they get lost. If you have this fitting, make sure it is installed in the midsection when installing gearcase. Stick it in with grease or something.
To install the gearcase: Tilt the motor all the way up. lock it up if necessary. Make sure the plastic water tube extension is in the waterpump output. Grease the splines on driveshaft and shiftshaft. Slide driveshaft into midsection. Insert copper water tube into plastic water tube extension. Push and hold gearcase into midsection. Turn flywheel until driveshaft splines mate. Push until shift shafts meet. They may mate or you may need to rock the throttle handle to help them mate. If you don't have the fitting, you may need to use a needle nose plier to move the shiftshaft, from outside the midsection, to help it mate.
Put a nut on the front stud and using only your hands (never wrenches), wiggle the gearcase on. Make sure the upper shift shaft is mated with the lower shift shaft, or it will be pushed up into the lower carb.
Kissdude
I will take it apart and try again. Can I bend the bottom carb rod spring thing back or is it finished now?
I do not know. The carb throttle shaft and spring are replaceable, if you can find a used carb to cannibalize.
On the other hand, it is just a spring. Maybe it can be bent back well enough.
Kissdude
Another question if you don’t mind. What is the lever for on my quick silver control box behind throttle lever?
I think you are referring to the fast idle lever.-----Used for cold starts and warm up.----It is to be all the way down before using the big lever for shift / throttle control.
Kissdude
So does this lever have to be up when you start the engine cold?
