Help me set up my new edelbrock 1409
Rugglesworth
I set mine on the trailer but it behaved the same in the water. The service manual for TBV says to set in the water.
So fire it up, jumper wire on, take throttle connection off, adjust idle screw and then adjust throttle cable and reattach? Anything im missing and have I done it right so far?
I would set base timing to 10-12 degrees BTDC
You set idle in the water in gear
