And just so you don't think I'm a total wanker, here's some other progress I made:
Back in August I pulled all the cushions out and took them completely apart. Turned out they used crap plywood and regular stapes and when it started falling apart someone just poured caulking into every hole. Once I cleaned up the sealer and separated the foam, vinyl and plywood I realized that everything except the plywood is in good shape (aside from the sealant residue) and it's not a difficult fix. I bought few pieces of Azek of various thickness and cut all the cushion bottoms out of it, bought marine grade staples and just put it all back together, came out better than I expected.
I also did some work on the trailer, the bunk board supports were too short and getting bent at the bottom, so we made some new ones using square tube, milled out the slots and left the bottom a solid so it doesn't spread again, new carpeted boards, wider rollers and improvised guide-ons made form what I had on hand, just need to add the bunks or put some PVC pipe over them so they don't scratch the boat.
Can't wait to get all this done so I can get out on the water soon
