richardldemers
Thread starter- Joined
- Dec 11, 2023
- 16
carb rebuilt, eliminated all electronics( went straight to battery.) coil is good. timing is set correctly according to the mechanic that rebuilt it. new spark plugs twice and new wires to plugs in order. pvc valve assembly is good. did a smoke test and found a leak in intake manifold gasket and I fixed that and retested and its good.
I'm at a loss. If I spray a steady stream of WD40 into carb while running in about 2 to 4 seconds it stops backfiring. When I stop spraying in about 2 to 4 seconds it comes back.
If I pull the #8 spark plug wire off while running , the backfire stops and engine idle goes up about 100 rpm and seems to run smoothly. What is going on???? Anybody ever have something like that happen? I've had all kinds of suggestions and pretty much tried them all, its been a mystery to a lot of people.
