redneck joe
- Joined
- Mar 18, 2009
- 15,493
Was it coosa 20 or 26? 26 claims to be a direct (and better) replacement. Also thought about upping to 3/4" since it is purportedly 30% lighter.
Isn't that what post 3 and 4 are?I wish he did a test trying to pull the screw through too. That concerns me more than the flexing strength.
My bad, I stopped scrolling at the first comment. I figured all his testing would be in the original post.Isn't that what post 3 and 4 are?
Ha, welcome to my world.My bad, I stopped scrolling at the first comment. I figured all his testing would be in the original post.
Note to self, learn to read.
Reading up on OTF and a couple questions.
Do I need to batch mix or will a full recipie store well, with no volatility like used rags?
On initial application, how will I know if the wood 'looks thirsty' for additional application?
For final three coats Mr Google tells me varnish or sometimes spar varnish or polyurethane or sometimes spar urethane but varnish and urethane are different so in his replies he suggests both to me. The below Pic shows specifics for initial recipies. Am I to use same minwax urethane for the (spar) varnish aka urethane for the finals?
My KF was 16 feet. I had to order another quart of Gluvit because I coated both top and bottom of each deck piece, plus the transom. One batch wasn't enough.Bwr, iirc your kingfisher was a 14 footer. How much recipie did you use?
I can't remember for the OTF.So two it's gluvit, and on the OTF?
ok, i knew you were a freak for the pink board but the gluvit on the wood would have elevated you to a new as yet undefined category...
