- Joined
- Mar 8, 2009
- 43,892
Agree, but that isn't what was said or tested, it actually "started"The TB troubleshooting guide starts with verifying the tach wire isn’t shorted to ground …
I worded that bad. The troubleshooting starts with the tach wire. The engine does not start.What???
The motor "Starts" with the Tach wire???
I disconnected the tach wire on coil with no luck. So now there is nothing on that post. When the troubleshooting guide starts with testing the tach wire you would think they would say to disconnect it and if it starts there's your problem. Why they don't mention that I have no idea. The only grounds I touched were the ones on the studs on the back of the motor and distributor module which are clean and tight. And I used an electrical connection/ corrosion gel on them (Dioxit) Any idea which ground directly relates to the coil not firing? I also have the battery on a charger and will check it again tomorrow but really don't think that's it. ThanksDisconnect the tach wire (grey) at negative post on the coil. This will remove any chance the tach is killing the spark
you can also disconnect it and check for continuity to ground with a volt meter.
woukd agree battery and connections both positive and negative are suspect given the voltage drop
Go through the rest of the TB troubleshooting guide.I disconnected the tach wire on coil with no luck. So now there is nothing on that post. When the troubleshooting guide starts with testing the tach wire you would think they would say to disconnect it and if it starts there's your problem. Why they don't mention that I have no idea. The only grounds I touched were the ones on the studs on the back of the motor and distributor module which are clean and tight. And I used an electrical connection/ corrosion gel on them (Dioxit) Any idea which ground directly relates to the coil not firing? I also have the battery on a charger and will check it again tomorrow but really don't think that's it. Thanks
It would appear that you found your problem. Nothing is connected to the neg coil?So now there is nothing on that post.
Good point . I have. 2 grey wires on mine one to coil one to tach. If no wire is on net post of coil It will not fire.It would appear that you found your problem. Nothing is connected to the neg coil?
There should be two grey wires connected to the (-) side of the coilI disconnected the tach wire on coil with no luck. So now there is nothing on that post.
In a previous post you mentioned removing the tach wire from the neg post will remove the tach as a possible issue. That is the only wire on that post. Removing it leaves nothing on that post. All my testing was done with the tach wire on. I removed it and tried it like you mentioned. It didnt help so I put it back on. Now I'm hearing there should be 2 wires on neg post? I didnt see any other grey wire coming out of the harness The distributor module ground gets grounded at riser like it was before I started. Is there supposed to be a ground on the Neg post of coil? Can I run a wire from neg post to neg battery post for testing? My biggest fear is frying something like the no longer made ignition module running test wires incorrectlyGood point . I have. 2 grey wires on mine one to coil one to tach. If no wire is on net post of coil It will not fire.
can disconnect the tach wire on back of tach Or check for continuity to ground with a volt meter
What Is the serial number of the engine ? Yes normally there are two wires on negative side of coil one to ignition module one to tach. But yours may be different hence the serial numberIn a previous post you mentioned removing the tach wire from the neg post will remove the tach as a possible issue. That is the only wire on that post. Removing it leaves nothing on that post. All my testing was done with the tach wire on. I removed it and tried it like you mentioned. It didnt help so I put it back on. Now I'm hearing there should be 2 wires on neg post? I didnt see any other grey wire coming out of the harness The distributor module ground gets grounded at riser like it was before I started. Is there supposed to be a ground on the Neg post of coil? Can I run a wire from neg post to neg battery post for testing? My biggest fear is frying something like the no longer made ignition module running test wires incorrectly
Post #28 and the link in post #29 have all the information you are seekingNow I'm hearing there should be 2 wires on neg post?
One for the tachometer signal and one for the module
The one for the module provides the "pulse" to let the coil fire. It basically takes the place of the ground wire in a conventional (points) ignition
Without the grey wire from the module, the coil will not fire. Check the module wiring harness, you'll see one of the wires coming out is colored grey and make sure it's connected to the (-) side of the c
Serial # 0l072052If y
If you ground the negative side of the coil you will kill the spark.
You can always take the signal wire off back of tach to take the tach out of the picture and continue on with the trouble shooting guide
This is the only before pic I have. It sure looks like only one grey wire attached to post. Got my head back there and see no other wires coming from the harness. Highly unlikely it got clipped pulling motor. The grey looking wire in the foreground is the black and for the distributor sensor which is newThere should be two grey wires connected to the (-) side of the coil
Without the grey wire from the module, the coil will not fire. Check the module wiring harness, you'll see one of the wires coming out is colored grey and make sure it's connected to the (-) side of the coil
The two grey wires are bonded inside the harness, so only one is hitting t(e negative post of the coil. Attached is a wiring digram for your engine (assuming alpha version).This is the only before pic I have. It sure looks like only one grey wire attached to post. Got my head back there and see no other wires coming from the harness. Highly unlikely it got clipped pulling motor. The grey looking wire in the foreground is the black and for the distributor sensor which is new
I'm going out there now step by step with the scratch test. Just want to confirm when using a test light on the negative post of coil to see if it lights up while cranking, the test light lead goes to positive battery terminal. Also have a new distributor sensor will try outThe two grey wires are bonded inside the harness, so only one is hitting t(e negative post of the coil. Attached is a wiring digram for your engine (assuming alpha version).
so go through the troubleshooting after disconnecting the signal wire at the tach.
