Thirsty Endgrain
Thread starter- Joined
- May 30, 2020
- 254
s/n 0T733923
Hi all,
Coming in the other day it started acting erratic, would idle and then bog down hard as soon as I put it in gear. Limped home at 6 knots, admittedly longer than I should have with a bogging engine but it was getting late/dark.
Assumed carbs since it's a Mercaha known for plugged jets/gumming issues, though I've always run Quickleen and the other additives to keep fuel stable since buying it and rescuing it from someone who couldn't get the carbs cleaned. That was a couple years ago and I figured it was time for a cleaning again, which I did. Put it all back together and realized it only has spark on cyl's 1/4. 2/3 had no spark, so I replaced the coil. No change, so I traced wires back to the ECU, which is providing only intermittent signal to the 2/3 coil. Does this confidently condemn the ECU? Are there any other lines of troubleshooting I can do? I already ordered a used one off of ebay to get it on the way, but if I'm missing something that someone knows of I'd appreciate any advice. Thanks.
Oh, I made a video of it surging in and out of spark, not sure it would help troubleshooting, but figured it couldn't hurt. I was poking around at the wires to see if it was a loose connection somewhere, but couldn't confidently reproduce the surging traced to any one wire/harness or the other.
Hi all,
