1990 Evinrude 9.9/15 still starting rough
jitterbug127
I have rebuilt carb, installed new fuel pump, new spark plugs, new fuel lines. Motor runs great once it gets warmed up. It idles low and will run all day once I get it running. It’s difficult to cold start especially and can be difficult to warm start at times. I installed tach, but I am getting abnormal readings. (Like exactly double most of the time). So the tach hasn’t been super helpful. Suggestions what to do next? I thought if I could increased the RPM just a little at start it might resolve the entire issue. Video below better elaborates on what I’m asking.
jitterbug127
I’m getting about 21 mph out of motor have had it out fishing a ton this spring and used it several days each week, I’m still confused on how to dial this motors start in.
Crosbyman
try openning up the LS needle 1/4 CCW . Starting an engine is done by pulling fuel from the LS circuit of the carb and make certain that little tube is set properly
jitterbug127
Thanks for the suggestion! I sometimes forget about his page. I will try turning my idle speed out and see how it goes. I do have that motor set to such a low idle i can see that being a problem.
jitterbug127
read through a bunch of the leeroy rambling website. Tons of great and useful information to try!
jitterbug127
Got it! (Atleast I think) simple enough fix. I didn’t realize that knob on tiller handle next to kill button could be adjusted: mine was tightened down all the way not allowing me to manipulate Rpm in neutral. I can get higher rpm to start and throttle down for idle speed:
jitterbug127
so what are you saying... problem fixed ?
Yes. I did some garage starts last night and seemed to work. I had the rom around 850-900 which is good idle a little too slow for the initial start (atleast with this particular motor). No ability to turn throttle handle at all made me stuck at 1 option for rpm in neutral, either 1 lower rpm for idle or 2 a higher rpm to start but no way to lower it. Being able to turn throttle handle just that 1/8th a turn or whatever it is has made a huge difference.
jitterbug127
Came home from work to do another cold test. Still hard to cold start motor. I am going to start looking for a leak of sorts. I think that’s probably the next issue.
jitterbug127
Went fishing last night motor started in about 3 seconds and ran just fine. Ill take it out a couple times this week and see what happens.
