Freeman1982
Thread starter- Joined
- Aug 19, 2020
- 89
Volvo penta
40869324
A196003
50gxic270r
Hello my friends, I need your help please
After getting error code close loop gasoline bank 2 I changed all O2 sensor, and turn on the engine. engines started but it’s look like having misfire, shaking bad. And smell gasoline so bad, I thought the fuel injectors is the problem because I replaced them couple weeks ago.
so I put back the OEM fuel injectors and turn on the engine and same issue shaking and smell gasoline. And later I tried to start the engine it’s won’t spinning and making weird noise like metal hitting metal, After that I open all the spark plugs to see what going on, it’s surprised me the spark plug on cylinder #3 left side when I opened it start pouring gasoline from the cylinder. I never see something like this before, So after that I made my compression test and got the psi numbers as below
Left side
C1=160 psi
C2 =150 psi
C3=160 psi
C4= 135psi
Right side
C1=135 psi
C2=120 psi
C3=130 psi
C4=135 psi
Please let me know what is the problem
40869324
A196003
50gxic270r
Left side
C1=160 psi
C2 =150 psi
C3=160 psi
C4= 135psi
Right side
C1=135 psi
C2=120 psi
C3=130 psi
C4=135 psi
