Scott06
- Joined
- Apr 20, 2014
- 7,372
Stop with drama, they sell Marine power long blocks (new GM marine) as well as merc bobtails and rebuilds. Doubt they are recommending oil that would cause a warranty issue or lessen engine life. Also doubt that the seller (merc) would recommend anything that doesn't have their label.Scott, Is your engine made by Michigan Motors?
Now my knowledge is dated, but my MerCruiser called for SAE-30 or SAE-40 or the Quicksilver 25W-40. I have seen newer four cycle marine motors that specified an FC-W oil, but never diesel motor oil.
Run what you want, but please update us on the failure cause.
Failure cause? there is no failure I'm on my tenth season of heavy watersports use. Typical use is our kids plus some friends - so 6-7 people towing a skier or wakeboarder.
I bought a handyman's special (non running) where PO cracked the block...
Point being - for 99% of recreational use there are plenty of oils that will work just fine. Most of the failure mechanism is neglect either poor winterizing, rotted exhaust manifolds, or not changing the oil or checking level. Stay away from the 0W-, 5W-, 10W- and you will be fine
