froggy1150
- Joined
- Nov 3, 2017
- 898
Whe have been pushing 118+ deg here in vegas...
Here are all of the video clips from Wilson Lake.
OMC Cobra drive noise:
The wife and I were out on the lake yesterday for the first time this season.
We rode from the ramp to the ski area and opened it up a bit. I made a turn and continued, then decided to throttle back. When I did, I heard what sounded like a dry bearing all of a sudden. I may have heard a bit of a clunk or pop, as well. I continued to slow down and let it settle back to idle speed. The sound got quieter, but was still there.
We were in open water with no chance of running aground. I didn't see any debris. Prop was fine.
We continued, trying different conditions to narrow down what it could be.
I got back on plane and it was fairly quiet, but still there. High speed, low speed, straight or turning. It wasn't loud, like at first, but we could still hear a faint dry bearing sound. It sort of resonated through the hull. The engine compartment sounded normal.
The sound was not affected by steering.
When I tilted the drive up or down, it would get quiet until the angle change was complete. It only got quiet during the movement, as if the effect on the drive shaft was making the bearing behave.
It makes the noise in forward, reverse and neutral, so that (to me) narrows it down to the input shaft of the drive.
At this point, I am fairly convinced that it is the gimbal bearing going out.
I suspect that the bearing's internal cage failed, causing a bearing to wedge momentarily and go back in place, causing the pop noise followed by the dry bearing/scraping sound, caused by the bearing cage. After several seconds of dragging, the bad part of the cage likely polished in enough to get quieter.
Do I sound like I am on track, here?
you can leave the nipple in the hole wont bother anything if you are using a perma lube bearing. Pull the drive and see how it looks since moving it helps would think it is gimbal or ujointsI should add that the bearing was part of an all-in-one kit from China. I should have bought quality parts from Iboats.com
The gimble bearing I got wass sealed; no grease hole to line up with the hole in the housing.
I still have the grease fitting in the hole, but someone told me that is a bad idea with a sealed bearing. You are supposed to replace the fitting with a plug to keep water out. Seems odd to me, but I guess it's a thing.
That said, I am going with a greasable bearing and OEM parts this time.
Honestly? I haven't pulled the drive since I finished the restoration back around 2021. I don't take the boat out much, or for very long at a time, so I have ignored that maintenance.When was the last time you pulled the drive and checked for water in the bellows. bearing condition and drive alignment? You should be doing this annually or at least semi annually.
I hope that's all it is. I'm anxious to pull it apart, but I won't have parts and tools until later in the week. I don't want to block my driveway all week, so I will just get ready and wait until the stuff gets here.if you have a cheap chinesium bearing in there, that could well be the cause of the issue... the bellows and bearings in those kits are not the best... I use them when resurrecting a boat, as they will keep water out until the hull and driveline is proven, but beyond that, if you get a year or two out of them, you did beyond great...
there is no need to pull the nipple on the grease port... the nipple is self sealing (or should be) and isnt a water intrusion point. You likely just got a cheap bearing, that is doing cheap bearing things.... (likely short on grease when made, and since used, is under lubed and running loud)...
At least itās an easy fix. If it was part of an Amazon kit, chances are it was ābadā right out of the box.Crunchy bearing confirmed.
Waiting for the mailman. I should have everything today.
I don't know yet if the boot failed, or if I botched the installation. Waiting for storms to pass and parts/ tools to arrive before I continue.
How was the alignment?Got it apart. Both ends of the bellows were still sealed. Showing good contact all around.
No splits in the bellows, but there is dry rot. Probably a tiny leak from that.
I bought and installed this chinesium bellows in 2020.
I expect the genuine replacement (made in Italy) to last longer.
The job was going well today, but I kept having to stop because of storms. Hoping for better weather tomorrow so I can finish up.
