Seastar hydrolic steering testing
Chuck4741444
I'm having problems after I hit the motor putting extreme pressure on. I lost my steering.
Things done i have bleedit to death many times.
I have removed it an totally disassembled it twice, every thing was oily and spotless clean, removed the 4 springs and ball bearing twice. Secondtime I pulled the side caps.
Today I'm test the pump the only way I know. I have installed a 3 way valve with a gauge and plug. When I turn it I can feel each internal cylinder clicking as it turns, im getting to 75 psi per click. It pegs my gauge at 300 pluse. Each way.
Is the pump bad?
dingbat
Have never seen a "dirty" hydraulic system. It's always a stuck/sticky valve of some sort or seal blow-by
Seals in a hydraulic system are not reusable. If you pulled the caps, the seals need replaced
Is the pump bad?
What have you done to resolve the lose of the check valve in your earlier post?
Why do you think the pump is bad?
You should be able to move a motor (swivel in good condition) with very little pressure. 300 PSI should be more than enough.
Is the pump sized for the cylinder displacement?
Chuck4741444
I found the problem, the polymer seal on the plunger is letting fluid through. I stopped testing pressure at 300. That's all my gauge read, I could get more press.
I have found a company that sells the rod with the plunger and seal together. For about 125.00
I couldn't find the o-ring and the polymer seal. Sold separately online.
Chuck4741444
I tested the pump with the lines disconnected using a 1/4 valve and gauge on each hose, i could see it moving pressure from one line to the other...
It's a bad plunger... thank for responding.
dingbat
Like these?
Chuck4741444
Ok I'm ready to flush the lines a clean the pump. Do I use gas, parts cleaner in a can or acetone?
When in putting the plungers back in should I lube them with hydraulic fluid?
I have one stupid question.
With the 7 plungers facing down. How does the air get out of them once installed. Should fill them with oil with the pump upside down?
Thanks for helping.
dingbat
Lines don't need to be "sterile".
Flush with clean hydraulic fluid
All seals should be lubed prior to installation
Thanks for helping.
Displaced by the hydraulic fluid
Chuck4741444
Once the pump cylinders are connected at the console. They would be like turning a cup upside down and pushing it into water. The air has no place to go. Are the design to hold air? Like a shock exorber?
Im disassembling, it tomorrow. I'll send pictures to explain the questions i'm asking
Chuck4741444
What do i use to clean the inside pump and cylinder i bought a new plunger for it. I want it clean. As possible.
Thanks
