Evinrude big twin 40
Open Water
I have a 1967 Evinrude 40 hp big twin electric shift. My issue is with milky lower unit lube. Had it air pressure tested and held for a full day. Fella told me it looked like the seal had been changed. I’ve changed lube a few times this summer, it’s worse after I run it in higher rpm’s. To me two things are different from pressure testing or in the lake. Drain and vent plugs and RPM
jimmbo
Welcome to iboats
Likely the Seal under the Water Pump.
Have you tried pulling a Vacuum on the Case?
Looking at the Pic, the Boat looks like it is nice Condition
FYI, Your motor was called 'LARK'. 'Big Twin' would have been used for the Mechanical Shift models
Are you checking gear oil 1 hr after your trip or 3 days after your trip ?
Open Water
Thanks I’ve done a lot. No vacuum yet, I think I’ll just replace the seals. Would you think the screw washers are bad. I’ll change those 1st.
Could be tiny air bubbles.----Let sit for 3 days and check.
Open Water
Don’t think so, I save each drain store in clear bottles. Some have been still for over a month. A thin layer of clean oil near the top.
Open Water
Well all be go to…. It says Lark on the back.
jimmbo
The Washers on the Screws should be replaced every time the Screws are removed/loosened.
Best to look after that electric shift gearcase.-----New seals are cheaper than the springs , clutches and gears.
tphoyt
Yea unless your a serious time crunch May as well do the seals and be done with it. Then you know everything looks as good as the rest of the boat.
kbait
Use omc premium blend or older type c in your electric shift gearcase..
airshot
Very cool looking boat and motor, brings back memories from my youth. Hopefully we will see the boat in action when you get the bugs ironed out !
jimmbo
As Mentioned about the Gear Lube, but beware that some 3rd Party Oils claim to be Type C, but then go on to say they are NOT Compatible with Electric Shifts
Open Water
Well folks I’ll have to go ahead and change the seals in this lower unit. Found new washers for vent and drain. I use Sierra brand type c lube. Ran it at the lake this morning, still came out looking like chocolate milk. I have had the parts on order for a few days. I’ve changed the water impeller, so I can get that far. Any decent blown up views on how this electric shift is put together. Model 40778E. SN E02326. 40 hp Lark
tphoyt
I may have a manual but I’ll have to look for it.
That could be a challenge. If all else fails take lots of pictures.
Open Water
Welcome to iboats
Have the lower unit off. Bingo!
