jimmwaller
Thread starter- Joined
- Nov 30, 2013
- 274
Hello, I am trying to drain the gas tank on my boat as it has been sitting for quite some time and the gas is likely bad. Here is a photo of the park of my tank I can see:
First, I just want to make sure I know what everything is. I labelled the main parts above.
1: I am not sure what this hose goes to, but I'm going to trace it later
2: This is my fill line
3: This goes to my engine
4: this is electrical and at least some of it goes to my sending unit
5: this is my fuel sender unit
6: I am not sure what this is
So here are my specific questions:
1) Hoes does my tank look in general? I know that it's hard to asses from a photo, but does anyone see anything that make them think "oh wow this tank is falling apart like tomorrow"
2) I have some corrosion on the fuel send unit. I kind of want to take it off and clean it, but is that a bad idea for any reason? I imagine that I can just pop it off and then back on, but I've never done this before so maybe it would need to be like calibrated or something and I want to make sure that I can just pull it right off and put it right back on before I mess with it.
3) My actual main question is... I'm trying to drain the tank. I have disconnected #3, above, the hose that goes to my engine. I tried putting just a priming bulb on there and sucking the fuel out, but the priming bulb didn't have enough strength. It felt like it locked up, like there was too much vacuum pressure inside the tank or something for a priming bulb to get the fuel out? I know people usually use pumps, but I figured that I would try a bulb first and just manually pump the fuel out so I don't have to buy a whole pump. So if my priming bulb just doesn't have
enough power to get the fuel out, I figured maybe there's a vent or something I can open that would release the vacuum. I saw #6, above... it kind of looks like it's a vent? I can't see anything else that it obviously does. Anyone know if this is a vent and if cracking it would allow me to pump the gas out? Or maybe if my fuel sender can just pop off and pop right back on, maybe I can pump it out while the sender is off? Or is there some other trick to getting fuel out without a pump?
Thanks in advance!
Thanks in advance!
