Gauges don't work
beckoning
Just bought the 2005 G3 boat (19') with 150hp Yamaha. Motor and boat come from Yamaha as a package. Neither the tilt gauge nor the volt gauge seem to work. Where to start with diagnosing? My first step will be to take the screws out of the instrument panel and lift out the entire panel for access to the back of gauges, and check wiring. Are the gauges fused? Does anyone have a wiring diagram. Call Yamaha? What could be the problem?
MikeSchinlaub
Ensign
I'm not an expert on the electrical stuff, but there should be a fuse panel somewhere. Also, the gauges are all chained together with jumper wires. The jumpers are the power supply to the gauges. So those would be good things to check, fuses and good connections on the power wires.
jlh3rd
there should be a purple colored wire running to those gauges that supply power from the ignition switch normally. I'm assuming yamaha follows marine wiring color schemes.
So if you pull the panel, check for voltage at that wire when turning the ignition switch on. If no power, then work backwards.
mike_i
This doesn't answer your question but did you just buy the boat from a dealer or private party?
check the grounds to the gauges. normally the grounds are daisy chained to the ground buss
check the power to the gauges. normally the power is daisy changed to each gauge and runs to the ignition switch.
the yamaha factory service manual will have the schematic for the engine, controls and gauges (not the boat)
ESGWheel
Ensign
As highlighted, these are daisy chained together and thus if other gauges are working, then is probably not a fuse issue. Example: does the Oil Pressure gauge work? If yes, there is power and ground to that daisy chain. While it may be a the daisy chain connection to these particular gauges being bad, I suggest it’s better to crawl under the dash (if the wiring is accessible that way). Pulling out the panel can lead to more issues as the wiring generally does not have ‘excess’ to pull out and due to the probable crimp spade connectors used, you may disconnect some of them by accident.
If you do not already have it, you need a Multimeter (MM) along with some alligator type leads. These leads allow you to clamp onto a connection and not have to hold the probe there. Very useful. Here are a couple of suggestions link and link.
With these you can check both the Pos and Neg “power” for the gauges > if you need assistance with “how to” please ask.
Also, I suspect that your tilt and voltmeter gauges are not working for different reasons. But first check they are powered properly and let us know.
MikeSchinlaub
Ensign
It can still be a fuse. A lot of them I've seen, the power is chained to the fuses, then from fuses to gauge.
This sad diagram shows what I mean. I usually see this kind of thing on older boats, where the dash has a panel with those glass tube fuses. Sometimes its own panel, sometimes with the gauge it powers. So a blown fuse won't kill power to the rest of the cluster.
This diagram really should be in crayon.
ESGWheel
Ensign
“Sad diagrams” still carry the point, so all is good, thanks for the info. While I am not familiar with the older boat designs, current boats (I assume) follow the protocol of the fuses protecting the wiring and not the device. For example, my 2005 Larson does not have fuses for each gauge. The “why” the wiring vs the device is best explained by Nigel Calder in this short vid link.
Regardless of which way this is wired having the MM with the clamp on leads will help the OP determine the issue.
jlh3rd
My '06 pontoon did not have daisy chained gauges or accessories. I rewired mine and did daisy chain all switches. The gauges have individual purple wire supply. I can pull my panel off as there is/was slack enough, so don't assume there isn't. The purple wire from the ignition supplies power to the gauges only when the ignition switch is turned on. The inline fuse from the battery (red wire) to the ignition switch protects all connections from the ignition switch. The gauges are not individually protected.
Don't assume anything, use all resources to verify how components are powered.
jlh3rd
and I didn't have busses. It's an '06. One reason why I re-did my rat's nest from the factory. You may not have busses either.
I added them.
beckoning
Thanks to you all. I have a MM, alligator clips, and some DC experience, so I have my work cut out. My dash pulls out, which I will do gently, and confirm connections, then start using the MM to confirm power to/from (ie POS & NEG) switches. If power to/from is good and no gauge reading, it could be what sends the signal to the gauges, or the gauges themselves. Zero gauge readings seems rare.
beckoning
My 2005 G3 has a fuse bank or fuse board with new type spade fuses. Very nice. As far as I can tell, each gauge is NOT fused. I'll keep working at it. Need to crawl under, lay on my back, prop up my head, have a big trouble light, and do the MM tests for power. At 81, I may call one of you to come pull me out once I get under there.
The gauges are all daisy chained together on both power and ground
