Throttle levers 'stiff' at higher RPM?
Lycon73
Larson Cabrio 310 with twin Volvo Penta engines, the throttle levers seem relatively smooth at idle but when boat gets up to speed shifting gets harder and harder, particularly shifting DOWN on both throttle levers from forward to neutral. The shifter cables are brand new, shifter itself doesn't seem to have any obvious problems. Some said it can be something with the drives, while another mechanic said with Volvo engines there's a mechanical pressure at higher RPMs where it's normal for throttles to be 'harder', which is different to the Mercruiser system, according to him.
Anyone know what else it can be? Nothing overtly wrong with the drives, which are Volvo SX as per user here who identified them, and seem in good condition.
MikeSchinlaub
Ensign
I'm not an engine guy, but have you tried them with the engine off? They might be binding up as they extend. That's the best I can do.
Lycon73
Yep, with engine off they seem fine and are relatively smooth. For some reason only get very 'stiff' when boat's moving at higher speeds.
Davetowz
Check for worn motor mounts, perhaps there is movement that is causing some binding.
