J90ELEDR Cooling Concerns
Big Jay
Hello again to all, this is a bit long winded, apologies ahead of time!
I'm the 3rd owner of a J90ELED 1996 90hp Johnson with the 60⁰ block. The engine is in fantastic shape inside and out, it's been very well maintained and cared for. It has been a freshwater beast its whole life here in Ontario Canada, and after changing the plugs (130psi in all 4 jugs) and rebuilding the fuel and OMS systems, she runs beautifully and reliably.
I do however have one issue that had been plaguing me: the cooling system.
I'd installed a full impeller kit, and she pumps water nice and strong, but I was still seeing varying temperatures, just a bit too hot to be considered ok.
I then swapped out the thermostats, but at the time of purchase was somehow not told about the related thermostat seals. That said, when I removed the original thermostats, I found no seals in the assembly other than the O-rings on the large plastic nuts. So I thought maybe the previous owner has forgotten to install them.
I source new ones, put them on the engine-facing end of the thermostats (seemed like a no-brainer) and reassembled. It ran much cooler at this point for a trip or two, but now I'm finding a hot block at the end of the day again. Not hot enough to set off the alarm, but I need to remove my finger after 4-5 seconds.
I double checked the parts-explosion pic online, and I'm now seeing that the seal (#26 in the pic, a rubber covered metal washer) seems to be installed "between" the cylinder head, gasket, and the block!
Can someone please confirm or deny this?
If this isn't the case, the original seals could've easily fallen down into the water jacket when removing the thermostats, and could be providing restriction of water flow causing my intermittent overheating...
I have a full engine gasket kit on hand, and can easily pull the heads and rectify this, should this be the case..
Any direction or advice would be greatly appreciated!!
tphoyt
Do you have an IR temp gun to get an accurate reading? I’m not usually a fan of cheap tools but I have have an $8.00 gun and $70.00 gun and they both work the same so in this case chep has worked for me. It’s a very helpful tool. It’s hard for any of us to help find a blockage if you think that’s what’s happening.
Big Jay
I do, she was reading upwards of 107⁰ Celsius before I installed the missing seals. Way hot.
Once the seals were in it read around 40-70⁰ on the good days, but back up in the high 90⁰'s on others.
I really just need to know if I've got the seals installed in the right place. If so, then I'm thinking the originals may have fallen down into the water jacket, due to my ignorance. I simply didn't know they were there lol.
There's a guy on YouTube with the 150hp 60⁰block from the same model year who posted a vid changing his thermostats, but I saw no indication of any seals while he did this. Same style 'stats as mine, same large plastic retaining nuts and springs.
Furthers my suspicions that the seals are between the block and cylinder head..
Just looking for confirmation before pulling the heads on mine.
saltchuckmatt
Can't really answer your question but if you're running that hot and your alarm is not going off you have something wrong and the alarm system. Is the control box horn giving you one beep at startup? Otherwise test the sensor on the heads.... Easy to do.
I'm surprised you can keep your finger on the head for four to five seconds with that kind of heat
Big Jay
Alarm self test beeps without issue, all lights function. I think the manual says the heat alarm goes off around 117⁰C, but it's yet to trigger for me. It's also possible my estimation of upper 90⁰s may have been high, I didn't have my temp gun with me after the first couple runs that it stayed cool, as I'd thought I'd had it licked.
Manually touching the engine after that first seemingly misleading "cool" run or two, the block was what I expected.. luke warm to the finger touch, slowly warming a bit more once the water drained after trailering the boat, but never hot enough to make me pull my finger away. The subsequent runs I found i could only hold my finger there for a few seconds, and that was moments after pulling it from the water.
Big Jay
Anyone know the correct orientation of the thermostat seals on this engine?
saltchuckmatt
Shove a metal pick down into the tan wire under the clear or black rubber cover coming from head sensor. Ground it to a head bolt and see if your alarm goes off.
I'm betting your sensors are bad because your temp readings are to hot.
The orientation is a no brainer on this....shows it clearly in the parts breakdown. Is this a saltwater motor. Somewhere you have restricted water flow.
Big Jay
If you go to the 5 minute mark of this video it should show you everything.
Different block. Wrong thermostat assembly.
I've changed the standard all-metal thermostats on older outboards before, but never this plastic style. Hence why I missed the corresponding rubber-wrapped seal.
Big Jay
I mentioned this is a freshwater unit in my opening post.
I haven't pierced the tan wire and grounded it, but I have pulled the sensor from the block and grounded the sensor itself. The light came on, but no beep, likely because the engine needs to exceed 1000 rpm for the safety system to engage.. my motor wasn't running at the time.
Does this not simulate the same test as piercing the wire?
Thanks much for your replies so far... just trying to figure this out!
saltchuckmatt
I believe your incorrect. Same block and it's the newer style with the round plastic access covers with a o-ring. Other style is at the back near the bottom of the engine.
saltchuckmatt
You don't need to pierce the wire in there. You slide your pick in-between the wire and the wire cover until you hit the metal connector.
I would think the sensor would ground out internally not in the body of the sensor but I could be wrong.
Did you check both sensors?
how are you checking head temp? that alarm will go off right around 240f, which prompts me to swap the tan/blue sensors with the earlier solid tan ones as they will trip around 200f, thus giving you more of a cushion before its too late. anyway, see the cast-in flat spots at the top of each head? thats the ONLY place you take temps. if you do it near the plugs, you will get wild readings and get yourself into a rabbit-hole.
Big Jay
Thanks for the input. I've been away because of work, and only saw this now.
I'm using an electronic thermal temp sensor gun.
Turns out I was partially right. Those rubber coated metal gaskets do in fact go between the cylinder head and the block, and upon further inspection I can now see and feel the originals in place. I had been running it with a second set mounted on the thermostats themselves (dummy lol), thinking they were missing.
After cleaning all the old hardened grease out of the orifices and threads (and removing the second unnecessary set of gaskets), I've put a fresh light coating of Yamalube marine grease on the narrow end of the plastic thermostat housing (that goes into the head through the rubber coated gaskets) and the O-rings on the large plastic nuts, and buttoned it all back together.
I ran it afterward (just before seeing your comment about only taking readings from the flat area above the head), and am getting temps between 65⁰ - 70⁰C at the top of the head itself, I didn't know at the time to take the reading off the block where it's flat, so these readings came from just behind that spot....
And you're right, the readings around the plugs are still astronomical, bouncing in and around 88⁰C to 112⁰C.
Scary when you're in no position to replace your outboard!!
