I forgot to include that I went through the choke setting and found they weren't precisely right so fix that. Also the carb butterfly valves were not precisely synched so really took my time and got them right. So we'll see.Thanks for you input Nordin. Real expereinces are critical to setting proper expectations.
Ok, checked ignition timing just to be sure and it is correct and it is. Point gap is correct. I am sticking with the tower to carbs length adjustment that seems like I may be adding a bit more advance overall. I have settled on 1 1/8th now on idle screws so that is heading in the right direction. Left it alone for 45 min and started it right up with no choke or throttle advance. Left it alone again. Cylinder head was around 100 degrees. Fired right up. WOW! Ok I'll try to calm down. I have been here before. I still need to run it on the lake. Can't wait to do that and post the results.
Sound advice for sure.....Handle it with care and do not run the hell out of it.
That's what I tell people......but they just call me "cheap" anyway!You are doing a historic nostalgic deed to preserve it.
