New sea pump front seal walking out. Causes? Fixes?
twalt42
Installed a new sea pump (probably a rebuild) at the end of the season last year on a 1995 Mercruiser 454 Magnum serial F305183. While dealing with some other issues this season, I noticed the front seal on the pump was working itself out. It was cockeyed a bit on it's way out protruding more so on the starboard side of the pump housing. It looked ok and I managed to get it back in but not fully seated. There was no leaking of oil or water. Note, the pump also drives a mechanical fuel pump.
Questions: Is there a easy means of reseating this seal? Also, what might cause such an issue outside of a bad seal or rebuild? My first thought is the belt might be too tight even with a half of play in it.
I would appreciate any thoughts you might have. Thanks!
Tom
dingbat
Tom
Seals can walk for any number of reasons:
Not properly seated
Wrong size seal
Out of tolerance housings and or seals
Bent shafts
Bad bearings
Thermal issues
twalt42
Not properly seated
Wrong size seal
Bent shafts
Bad bearings
Thermal issues
Thanks for the response Dingbat. I managed to dig up the invoice and found this was apparently new in the box and not a rebuild. It doesn't mean it can't be bad but the original units seal did the same thing last year when I was winterizing. I will be doublechecking its alignment and belt tensioning.
I would pull the seal, get a new one and install with a bit of permatex around the outer edge.
