It rained on my fresh, wet paint!
BWR1953
What to do? The only thing I can think of is to let it dry, then deal with it after that.
I did catch it quickly.
Any other thoughts?
flashback
I guess alot would depend on what you're painting and the type of paint but in the long run you will need to deal with the aftermath.
MikeSchinlaub
Yes, you'll have to let it cure before dealing with it. What kind of paint, how many coats, was it actually wet or was the surface dry?
Oil based paint is fairly resistant to rain. Latex, OTOH....
If it is bottom paint, let her dry and maybe touch up a few places where it got wet.
BWR1953
Hi guys. I'm back home now.
I was on the 3rd coat of Krylon Fusion All-in-One spray can paint on the plastic console on my boat. Got it done and went in the house.
I had it hanging from my rear garage door. Bright blue skies, no clouds, about 85 degrees. Went in the house for breakfast after painting. I was sitting there sipping coffee when it started raining big, fat raindrops (Forrest Gump.) Sun was still shining and it was beautiful outside. (Florida.) I got out there and the console was wet and had some puddles in the recessed areas. Took it down and shook it off as best I could and laid it on a flat surface.
I'd post the pix, but I got my knuckles rapped a couple years back for posting the same pix in different threads. And I've forgotten how to link to a single post in a thread, but have called for help on that. :sneaky:
Anyway, the pix are in my Mirrocraft thread (see my sig) on Page 12, about Post #222 or so.
MikeSchinlaub
3rd coat in 85 degrees for about 10 minutes, it might be ok. I would let it sit overnight and see how it cures.
As I stated in your build thread......
use your leaf blower to blow the rain off..... you will be fine.
the worst case, scuff and another coat
tphoyt
Maybe your in to a new look. Clear coat it and tell everyone you paid big bucks for the affected 😂
MikeSchinlaub
Actually, there's a real technique similar to that. I've only seen it on an episode of Counting Cars, but if I remember correctly, you spray water on a panel, dust it with base coat, and let the water evaporate. It's supposed to give it that rain drop look.
MikeSchinlaub
I would treat it like you're just starting the paint job. Clean with wax remover, scuff it a bit, clean again, and finally tack rag before spraying.
MikeSchinlaub
Missed my prior post, eh? 😜
You only mentioned doing another coat. I don't know your skill set, so I figured it would be better to have advice and not need it.
I've seen some stuff...
And done some stupid stuff myself.
